Axle? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2007, 04:13 PM
need strog32 chevy front doors
Last journal entry: Tbd
Axle?
I picked up a free front axle with mechanical brakes(1930's) and don't know weither its ford or chevy or.. Are ther any distinct feature that a ford front axle has verse others like the mechanical brakes or..
if its a ford front end i think i would have more chances of ordering spindle brakes verses if it was a chevy
i could order spindles and disc brake set up for my 32 chevy but will haave to pay a boat load for parts plus shipping where as if this front end is ford i could go down the street to Total Performance to pick up a setup already there for the ford.
Or i could find a late 1930's axle with stock drum brakes
when did ther stop using solid front axle in most of the cars?????
Old 09-01-2007, 05:03 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
Ford used a single transverse spring until 49. Henry Ford resisted all advice to use a different front suspension. He died in 47, and the company tossed the solid axle & had a coil independent in 49. So if your free axle is set up for twin leaf springs, it's not a Ford. (meaning twin pads where the springs sit)
Other lower priced cars started independent fronts in 33-34 on their more deluxe models like Chev & Mopars; but the solid axle came on their cheaper models.
If the spindles are beefy enough, you could adapt disc brakes to them. i've done it before on a mopar. I had to turn down the spindles on a lathe as well as shorten them & rethread the ends. I did not have a lathe; I met an old guy at a parts store pricing exhaust for his 67 chevy pickup. One question led to another, and I offered to do his exhaust in exchange for his time & lathe work Caliper brackets were easy to make for the 4 piston stationary calipers I used.
Old 09-02-2007, 12:08 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
A picture would help.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
7 and 5/8 rear end drivers side axle leaks fumplet Transmission - Rearend 7 03-02-2006 01:39 AM
Axle Information. M&M CUSTOM Transmission - Rearend 1 02-21-2005 01:37 PM
Axle Tube Number ID Help Morex52 Transmission - Rearend 2 01-08-2005 08:00 PM
front axle help needed 30dodgeboy Suspension - Brakes - Steering 25 11-15-2004 09:37 AM
1938 chevy 6" drop axle for sale landon4421 Suspension - Brakes - Steering 0 09-26-2003 04:20 PM
