Axle - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-11-2007, 12:37 PM
need strog32 chevy front doors
Last journal entry: Tbd
Axle
All right. Finally am set on using the original front axle that i have and buying a disc setup that bolts onto the original spindle. Question is how do i know for sure that my axle is chevy or not. All i know is that it was found in the back of someones woods.
I any one reconizies the axle from picts. please let me know.
bear with pictures they are big
http://www.hotrodders.com/journal_ph...1823565282.jpg
http://www.hotrodders.com/journal_ph...1866224271.jpg
Old 10-11-2007, 12:43 PM
http://www.hotrodders.com/journal_ph...1838392730.jpg
The axle has the chevy grease hub but i'm not sure if the it could be chevy cab on a ford axle
Old 10-11-2007, 12:57 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
All I can tell you for sure is that axle is not a pre 48 ford auto axle. Can you give us the bolt pattern dimensions? Can you get us a pic of the spindles on that axle?
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 10-11-2007, 03:25 PM
I wish i had access to the car. I was told that the other axle i got was from a chevy the wheels that were on it fit the axle i am in question about.
Now that other axle had long long leaf springs on it with helper springs on(additional leafs). Those leafs fit in the rear of the car.
I think before i buy theses new brakes i am going to have to pull the front axle off.
Old 10-11-2007, 03:40 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
I need to ask: Why worry about a disc kit right now?
I'd be putting my efforts into the body overhaul first. If you put a lot of time & money into the chassis and then want to bail out of that car, you won't get it back with the body the way it is.
Another reason to avoid new chassis parts right now is that they may rust up, hoses get dried out, etc.
Also, did someone try chopping the front windshield at one time??
Old 10-11-2007, 04:32 PM
You make sense. But I know i am going to keep this one. I don't think anyone would interested in it in its current condition. Any ways i was thinking of just getting it runing a drive it around as a work in progress. it will be down in 3 summers
ya i think someone tried chopping the front windshield at one time or replaced the front apron.
Old 10-11-2007, 07:19 PM
Youngster's Avatar
Axle
If you can check the king pin size, you might be able to swap a '49 to '54 Chevy spindle, that would give you a5 lug bolt pattern and open doors to disc brake conversions.
Youngster
Chassis Engineering Dropped Axle Dugg Suspension - Brakes - Steering 4 09-28-2007 08:12 PM
1999 Jeep Cherokee Rear Axle Seals - Help leejoy Transmission - Rearend 2 05-15-2007 07:50 PM
7 and 5/8 rear end drivers side axle leaks fumplet Transmission - Rearend 7 03-02-2006 01:39 AM
Axle Information. M&M CUSTOM Transmission - Rearend 1 02-21-2005 01:37 PM
Axle Tube Number ID Help Morex52 Transmission - Rearend 2 01-08-2005 08:00 PM
