axle on 8.2 posi rear needs replaced - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2007, 08:43 AM
i have a 72 gto that needs a new axle its an 355 posi rear end . its an 8.2 . i am having trouble finding one that fits. are any interchangable and where can i find one?
Old 07-18-2007, 12:32 PM
Chevrolet, Buick, Olds, or Pontiac 8.2? They were used somewhat interchangeably in 72. If the axle bearing presses on the shaft and retained by 4 bolts, you will have to find a used axle or have one custom made at Moser or Dutchman.
Old 07-18-2007, 09:42 PM
pontiac 8.2 . thanks for the reply
Old 07-18-2007, 11:53 PM
Might search at www.car-part.com , but watch out for Chevy-style 8.2's and 12-bolts, and other odd GM axles. Most places that list there have email addresses and/or 800 numbers so you can check. Look for axle shafts or rear axle assemblies.
I think '68-'72 A-body axle housings will interchange, but, again, watch out for different styles. You don't want to get stuck with an O-type shaft or something like that.
10 bolt rear end question 8.2 or 8.5 ?? nheron Transmission - Rearend 6 03-02-2008 08:16 PM
rear suspension/Welding on Rear Axle redsin Hotrodding Basics 4 05-30-2006 08:25 PM
cadillac rear axle? Fizz Suspension - Brakes - Steering 4 05-07-2004 11:02 AM
10 bolt posi 8.5" rear end 406chevelle Transmission - Rearend 7 02-23-2004 09:51 PM
Rear End - 5 bolt axle shafts into 6 bolt rear axle??? Blue Chevy Transmission - Rearend 0 06-07-2002 05:23 PM
