Axle code ID, help to decode? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2006, 05:28 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I need help tracking down an axle code from a 73 GM Impala
The stamping on the passenger side axle tube reads:
YAP058
I've had the cover off and discovered 2.73 gears which I believe to be original. Its a non-posi. The main concern I have is WHAT BLOODY AXLE IS IT? It has a 10-bolt cover with a 12-bolt carrier and an 8.875" ring gear.
The center casting numbers are a "G" in the lower left, either 80663 or 80633 in the lower right, and 8223 on the upper right. The upper left has the D/N code and mine is cast Dayshift.
Thanks.
Old 05-21-2006, 04:59 PM
406chevelle's Avatar
One of these days...soon
YAP058
1973 GM Passenger vehicle rear axle (could also be a 1975)
YA = 2.73:1
P = Pontiac
058 = 58 day of 1973
Thats all the info I have, hope it helps.
406chevelle
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
10 Bolt Rear End Axle Code TORI1 Transmission - Rearend 13 03-31-2006 08:17 AM
axle code s johnsquicks10 Transmission - Rearend 3 05-12-2005 09:25 AM
Rear Axle decode Scorpion8686 Transmission - Rearend 1 04-01-2005 08:09 AM
Rear End Axle Code for the Chevy S -10's Traps Restoration Transmission - Rearend 1 02-27-2005 11:05 PM
