axle code s - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2005, 10:04 PM
axle code s
have a 1990 s10 . i am trying to decode the axle code on it and having trouble finding a site with the info. anybody have any suggestions? the code is cxa c131 its a 2wd was a 2.8 auto. thanx for any help
Old 05-11-2005, 09:20 AM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
More info
Where did you get those code #'s is it off the axle tag or from the RPO tag? If you can give me the RPO tag code #'s I may be able to help you. It will be a G-- # that is on the sticker in the glove box there may be more than 1 G-- # so give them all. Also what have you done to your S-10 any performance upgrades? You say it HAD a 2.8 in it, does that mean you have installed a new engine.
Old 05-11-2005, 02:38 PM
thanx for the reply steve the #cxa c131 2 is off the axle tube the rpo # 6GQ1. i've installed 350 engine and 350 trans pretty much stock for now. thanx again
Old 05-12-2005, 09:25 AM
1931 steve's Avatar
Wiki Edits: 4
Need more code #'s
The GQ1 code, all that GM says about the GQ1 is "Axle, Std Ratio". Is there any other # such as GU4? if there is this I can tell what gear ratio you have.
I also have a 1994 S-10 with a built SBC 350. Just about back together with it, Should be done in a week or two. If you have any questions about your truck let me know.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
Rear End Axle Code for the Chevy S -10's Traps Restoration Transmission - Rearend 1 02-27-2005 11:05 PM
Axle Information. M&M CUSTOM Transmission - Rearend 1 02-21-2005 02:37 PM
front axle help needed 30dodgeboy Suspension - Brakes - Steering 25 11-15-2004 10:37 AM
Wrong axle cover? frankenvette Transmission - Rearend 12 08-09-2004 06:23 AM
