Axle and Driveshaft balancing - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2006, 06:32 PM
Anyone do this, can you do it yourself with a lathe and measuring tools? or does it involve a machine more like a tire balancing machine?
any websites with how to?
Thanks
Brendan
Old 02-03-2006, 10:33 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
You can balance the driveshaft yourself if you have some patience and good sturdy jackstands -- sturdy enough you don't mind running the vehicle with the rear tires spinning on them while you're under the car. A lift is safer, of course. Note that this requires the utmost care! USE AT YOUR OWN RISK.
That said, go to http://www.tocmp.com/manuals/AMC/197...ml/browser.htm. Look at page 9-14 and 9-15. The first method uses an electronic wheel balancer (the type that mounts on the wheel). At the bottom right of page 9-14 starts the manual method (without a balancer). I really don't see why you can't use the described manual method in a lathe as long as the ends of the shaft are held true.
Multi-section driveshaft ckucia Transmission - Rearend 23 05-07-2006 12:01 PM
1986 or somewhere around there s10 driveshaft angle problems fumplet Transmission - Rearend 10 01-16-2006 09:20 PM
Axle Information. M&M CUSTOM Transmission - Rearend 1 02-21-2005 01:37 PM
When narrowing an axle do you................. STATUTORY GRAPE Suspension - Brakes - Steering 5 02-19-2005 04:53 PM
69 chevelle driveshaft... jackyandjoe Transmission - Rearend 2 06-20-2003 08:49 PM
