Axle HELP!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2006, 06:22 PM
Axle HELP!!!
Really had to scratch my head on this one today!
Got a Ford 9" in our 69 Camaro, don't ask it came that way.
The ring/pinion lash is way out so I started taking it apart. Got to the access hole on the wheel flange to find out it's about 11/16 BUT the bearing flange nut behind it is 3/4!!!!!!!! Can't get a socket to the bearing flange nuts!!!
Couldn't get an open-end in either cause we have the Wilwood 4 wheel disk and Emergency Brake set up so I had to take the whole damn emer. brake apart before I could get an open-end on the nuts.
Here's the $64,000 question:
Do I mill out the "wheel flange access hole" or get smaller "bearing flange stud/nuts"?
Any help would really make sleeping a lot easier tonight, so many thanks if you have an answer!!!
Old 01-08-2006, 06:44 PM
3100 Special's Avatar
Street Rod Dreamin'
Last journal entry: Last post project for a while
That's weird. I've been in the process of tearing apart my first 9 incher. The nuts were indeed 11/16...socket went right through the opening. You did what I would have recommended...remove all of the brake workings to get a wrench on it.
I would go back to the original studs and bolts unless there's a reason not too someone else comes up with. Can't imagine what though. Beats milling the opening.
Old 01-08-2006, 07:02 PM
Axle HELP
Thanks 3100. I just went out and looked everything over and I have "Moser" axles, that much I know. I looked over the bearing retainer flange and the tube holes. The flange holes all look like they're supposed to have the large studs/nuts. I think maybe someone at Moser got the measuring mixed up. I guess the only real solution is to make the hole bigger. But I'm not real comfortable with milling out the access hole. Whattya think?
Old 01-08-2006, 07:10 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Well isn't that special?!!!
Could you possibly fit just the socket between the axle flange and the nut, and then stick the extension thru the access hole?
If your 3/4" socket is too deep to do that, could you buy a cheap one and grind it down?
How about one of those offset box-end wrenches ... could you sneak one of those in there?
If all else fails, the previous owner should know ... he must have got them tightened somehow!!!
Old 01-08-2006, 07:11 PM
Street Rod Dreamin'
I don't see that as a huge deal unless you're really taking away a large portion of metal and decreasing it's integrity.
From what you've described, you're not going to have to shave that much off and there shouldn't be any problems.
Old 01-08-2006, 07:24 PM
Excuse Me?
AAhh, "66GMC" did you read the part about the "emergency brake"?
Old 01-08-2006, 07:37 PM
Thanks 3100, I'm probably gonna have to do some milling. What you said does make sense.
Old 01-08-2006, 07:48 PM
66GMC's Avatar
Excuse me, too.
Admittedly, yes ... I must have missed that.
You have a slight advantage on the rest of us ... you KNOW what it looks like
There's gotta be a way ... the reverse of how it was assembled...
Lotsa luck. Be sure to let us know how you solved this.
Old 01-08-2006, 10:18 PM
Street Rod Dreamin'
Whoever did the origingal work must have put the bolts/nuts in place then, built the braking up.
This stuff is fresh in my mind! I disassembled mine yesterday, cleaned and painted today. Having never done one before, I was going slooooow and looking at everything, taking pictures, stratching my head, etc...
Old 01-11-2006, 04:51 AM
Answer!!!!
Just wanted to update all those that took a look at this.
Got hold of the good folks at Moser Engineering who claim they never heard of such a thing with their axles! They offered to drill it out though. I cant' see paying FedEx that kind of service charge though.
Moser approved my die cutter opening of the hole. Problem solved. All their machining is hand done so it was NOT a computer glitch. Maybe a human glitch? I think I should go play Mega Millions with this kind of luck.
Axle Information. M&M CUSTOM Transmission - Rearend 1 02-21-2005 02:37 PM
Axle Tube Number ID Help Morex52 Transmission - Rearend 2 01-08-2005 09:00 PM
front axle help needed 30dodgeboy Suspension - Brakes - Steering 25 11-15-2004 10:37 AM
1938 chevy 6" drop axle for sale landon4421 Suspension - Brakes - Steering 0 09-26-2003 05:20 PM
transverse spring & straight axle 26trackt Suspension - Brakes - Steering 3 01-19-2003 12:45 AM
