axle id - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-09-2006, 07:03 AM
axle id
i have a 12bolt front gm axle where would i look for the bill of material and or model#,gear ratio and whether its a limited slip or open diff? all i have found so far is GM and the number 8 what yall' think
Old 06-09-2006, 09:28 PM
Drain it and remove the cover. Look at the open part of the carrier and see if there are a couple of coil springs visible, with a couple of more hidden farther back. Or maybe just a flat, S-shaped spring. Those are signs of a clutch-type positraction carrier. If there's nothing in there but a finger-sized pin and some gears facing inward, it's a peg-leg. If it looks like the pic below, it's a Gov-lock.
Look around the outer edge of the ring gear. You might find a part number, usually 7 digits, and a series of four 2-digit numbers. Two of those four are the tooth counts of the ring gear & pinion gear. Divide the big one by the little one & that's your ratio. The other two will be the date of manufacture, month & year.
7 and 5/8 rear end drivers side axle leaks fumplet Transmission - Rearend 7 03-02-2006 01:39 AM
Axle Information. M&M CUSTOM Transmission - Rearend 1 02-21-2005 01:37 PM
Axle Tube Number ID Help Morex52 Transmission - Rearend 2 01-08-2005 08:00 PM
front axle help needed 30dodgeboy Suspension - Brakes - Steering 25 11-15-2004 09:37 AM
1938 chevy 6" drop axle for sale landon4421 Suspension - Brakes - Steering 0 09-26-2003 04:20 PM
