Axle Information. - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
Old 12-19-2003, 11:13 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
Axle Information.
Calculator link for Tire Diameter, Recommended Gear Ratio, Compare Gear Ratios, Top Speed Estimater, and Aproximate Axle Torque.
Drivetrain Calculator
THESE NEXT TWO SITES OFFER SOME SIMILAR INFORMATION,
BUT BOTH GO WHERE THE OTHER DOESN'T
A COMPREHENSIVE FORD 9-INCH AXLE SITE Thanks to "willys36@aol.com"
ANOTHER COMPREHENSIVE FORD 9-INCH AXLE SITE Thanks to "acr"
A very informative Transmission/gear ratio/tire calculator
Speedometer Calibration Calculator And Information Thanks to "Chevelle LS6"
Inland Empire Driveline Service's "how to measure for a new driveshaft" site.
Denny's Driveshaft "driveshaft measurement quik-chart".
THIS LINK CONTAINS SPECIFICATIONS FOR MOST OF THE AXLES THAT WE AS HOTRODDERS WILL BE USING OR INQUIRING ABOUT.
Plus, they sell gears and installation kits for them too.
Axle Specifications by axle.
Dana Corporation's Axle Expert Site.
Guide to the Chrysler 8-3/4"
Info on the tapered axle 8-3/4 rearend.
The Dana/Spicer 60, in Chrysler/Dodge/& Plymouth Vehicles.
Chrysler A-body 7-1/4", 8-1/4", 8-3/4", and 9-1/4" Axles from 63-76.
Calculators, Axle Information, Ring Gear Sales.
Randy's Ring and Pinion.
Ford 9 inch to GM G-body car swap done right.
The most descriptive Ford 9inch to GM G-body swap I've seen yet.
Ford Explorer 8.8 inch to Chevy S-10 swap done right.
A step-by-step swap with measurements & info to find the right axle.
I have to thank *KNathrup* for his hard work on his site and this information.
Ward Engineering-Jaguar Axle Supplies & Reconditioning. Located in the UK
Ward Engineering
The distance between the edge of one bolt hole on the wheel to the edge of the bolt hole right next to it will help determine the bolt pattern.
For a 5 bolt wheel:
If distance = 2-5/8" then the bolt pattern is a 5 on 4-1/2
If distance = 2-3/4" then the bolt pattern is a 5 on 4-3/4
If distance = 3" then the bolt pattern is a 5 on 5
If distance = 3-1/4" then the bolt pattern is a 5 on 5-1/2
Wheel patternt torque sequence.
Wheel Terminology.
I would like to have some of you PM me some website links to the MOST informative axle/rearend sites you know of.
I will check them out and post links here for everyone to use.
Quick reply to this message
Old 02-21-2005, 02:37 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
There is absolutely NO need to look at this post or any others that may follow in the future, as these are only open to allow more pictures to be added to the first post. The bulletin board software only allows three pictures to be loaded into each post, and that is what these are here for.
Don't bother wasting your time clicking on these as they are already posted for viewing in the above thread.
Closed Thread
