Axle Shaft Information - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2005, 11:34 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Hi,
I found this PDF catalog on Superior's website (which is under construction) and would like you to add it to your useful links.
http://superioraxle.com/pdffolder/su...atalog2004.pdf
They have a lot of very useful information there, including (I'm so excited...) 6-bolt to 5-bolt conversion axles to fit my 66 GMC! See page 15.
Don
Old 06-11-2005, 11:40 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
I will add it to the information sticky thread and give you credit for it.
I will edit this post when I do so.
Go Cart? mustangdude947 Engine 23 12-20-2005 10:02 AM
Axle Information. M&M CUSTOM Transmission - Rearend 1 02-21-2005 01:37 PM
12.5 hp go kart airbag_89 Introduce Yourself 2 08-24-2004 10:22 PM
Removing coil pad plates from axle Jackyl General Rodding Tech 2 07-24-2004 07:11 AM
axle shaft scoring 56don Transmission - Rearend 4 10-29-2002 12:13 PM
