axle splines - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-30-2006, 02:24 PM
axle splines
My question is to do with the compatability of a posi unit for a 12 bolt Chevy and the fact that I want to put axles with more splines. Can I change the splines on the posi ? I will not upgrade the axles if I have to get a new posi.
thanx, C.Price
Old 07-31-2006, 01:29 PM
S10xGN's Avatar
Gotta love a turbo!
Your best bet would be changing the side (and/or spider) gears to match your axle splines - IF THEY ARE AVAILABLE. Be aware that this will require some minor disassembly of the POSI unit.
Russ
Old 07-31-2006, 04:47 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Beaware that going to more splines means a bigger axle and you should make sure the axle to still slide into the carrier.
Axle Information. M&M CUSTOM Transmission - Rearend 1 02-21-2005 02:37 PM
pinion and axle splines red_rider52 Transmission - Rearend 7 01-17-2005 11:37 PM
How many axle splines? billybob_v10 Transmission - Rearend 3 11-25-2003 09:25 AM
axle splines??!!! how to tell?!? fireforsin Transmission - Rearend 5 09-13-2003 10:54 AM
