axle trivia - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2010, 07:56 PM
axle trivia
I have a 92 s10.I bought an Eaton carrier for my truck.I tore the rear down to find out I have a 26 spline in the rear of the truck but a 28 spline posi.Now,do the two axles interchange?I mean,are the lengths the same where i can get a pair of 28 spline axles to replace the 26's and use my new Eaton?Im pretty sure the bearing diameter is the same.Plus,any geusses on how many horses this rear might withstand with an automatic?Thanx in advance folks
Old 03-29-2010, 09:14 PM
big gear head's Avatar
High Performance Rear Ends
The axle bearings are the same and you can install 28 spline axles in the rear end that you have. This might be helpfull. http://www.nastyz28.com/forum/showth...t=install+posi
Old 04-03-2010, 02:09 PM
thanx its a big help
Old 04-03-2010, 02:46 PM
Wiki Edits: 31
yea.. Chevy went 28 spline in the S10 in '88 IRC, but used up the 26 spline stuff.. I'v heard of 26 spline rears right up to 1993
Problem w/ 8.5" C-clip axle joe_padavano Transmission - Rearend 17 05-15-2009 11:48 AM
94 Mustang axle loose, GT vs Cobra parts?? frankenvette Transmission - Rearend 7 07-14-2008 10:37 AM
Chassis Engineering Dropped Axle Dugg Suspension - Brakes - Steering 4 09-28-2007 08:12 PM
1999 Jeep Cherokee Rear Axle Seals - Help leejoy Transmission - Rearend 2 05-15-2007 07:50 PM
Axle Information. M&M CUSTOM Transmission - Rearend 1 02-21-2005 01:37 PM
