axle width info for 1956 lincoln premier - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2005, 09:02 PM
New Member
what its the width of a 56 lincoln 9" rear end, i can find any info on it. outside of drum to drum...thanks.sam
Old 03-02-2005, 11:33 PM
New Member
anyone know???
Old 03-05-2005, 08:18 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
I won't let a question die without an attempted answer, so I put it back to the top.
Old 03-05-2005, 09:16 PM
1956 Lincolns did NOT have the 9 inch Ford from the factory. 1957 was the first year for the 9 inch.........so......if it has a 9 inch.........it could be anything.....because it was installed at a later date......
Old 03-06-2005, 06:31 AM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
What is the purpose of the question, what are you trying to do? Do you need a rear for the car? If so, why don't you call some scrapyards and ask if they have any Premiers or if they know the dimensions you are looking for. A lot of those guys know this stuff right off the top of their head. Just a suggestion.
Old 03-06-2005, 09:43 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
I am thinking he is asking for the purpose of installing a different (and most likely better) axle in his car, but would like to know if there is a 9 inch that will directly swap or at least work with as little effort as possible.
Since I have little information on the 9 inch as far as swapping goes, I didn't directly attempt to answer your original question.
Old 03-07-2005, 06:17 PM
New Member
my mistake its notA 9" .. what is the lenght of it though, maybe it will work in my 28 roadster?looking for a rear end wondering if this one will do the job..sam
Old 03-07-2005, 06:26 PM
Lonestar's Avatar
Visit a local scrapyard and bring a tape measure. I searched on the net for the track width and came up with nothing.
Old 03-07-2005, 08:49 PM
New Member
i have a 56 lincoln, and ive tred the net also no luck on width, its just that the car is under 6 ft of snow and in a field...
Old 03-08-2005, 07:48 PM
Lonestar's Avatar
Grab a phone book and call some junkyards. You would be surprised at how much obscure knowedge they have from tearing down cars over the years.
Straight Front Axle Info KULTULZ General Rodding Tech 11 06-03-2004 02:26 PM
36 chevy stock axle rework info needed spuds1956 Suspension - Brakes - Steering 2 03-16-2004 04:30 PM
seeking drop axle info lilbill Suspension - Brakes - Steering 8 04-08-2003 04:07 PM
Width of S-10 rear axle? Dreamweaver Transmission - Rearend 1 02-28-2003 12:51 PM
Straight axle info? HemmiGremmie Suspension - Brakes - Steering 13 01-22-2003 04:46 AM
