b body hub assembly conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2013, 10:46 AM
hey i have a 86 caprice and i was wondering if it was possible to do a hub bearing conversion. i saw online about the g body conversions using calipers, hub assemblies and spindles from the 98 - 02 blazer and i thought that the g body and the b body front suspension aren't much different. just would like to use hub assemblies so i can change rotors and pads easier and less messy. any advice is appreciated. heres the link to a hub assmbly conversion on the g body.....sorry its from a different site, just needed some ideas.... http://gbodyforum.com/viewtopic.php?...5#.UUZhLle9A_c
Old 03-18-2013, 11:18 AM
Originally Posted by runway1589 View Post
hey i have a 86 caprice and i was wondering if it was possible to do a hub bearing conversion. i saw online about the g body conversions using calipers, hub assemblies and spindles from the 98 - 02 blazer and i thought that the g body and the b body front suspension aren't much different. just would like to use hub assemblies so i can change rotors and pads easier and less messy. any advice is appreciated. heres the link to a hub assmbly conversion on the g body.....sorry its from a different site, just needed some ideas.... G Body Front Brake Upgrade (13.4" Rotors) C6 Z51 (For Sale!) • GBodyForum.com - '78-'88 GM G Body Community
"Less messy" is because you have to touch the wheel bearings? How often do you actually change brakes in this car? I have a hard time seeing how this makes any kind of financial sense. B-body rotors are so inexpensive that it's cheaper for me to buy new ones than to have the old ones turned when I do brakes on mine (and I have the 12" rotors). It takes me about half an hour at the most to do the front brakes, and most of that time is spent finding where I left my tools last.
b body, blazer, caprice, g body
hub assembly breaking instantly 95 k1500 Catatonic21 Suspension - Brakes - Steering 5 06-27-2012 12:20 PM
TH350 Valve Body Assembly Help stinger12 Transmission - Rearend 8 04-13-2010 11:31 PM
Dodge Dana 60 front hub conversion automods Transmission - Rearend 0 01-06-2009 05:01 PM
Steering Hub Assembly 68NovaSS General Rodding Tech 1 04-29-2006 10:41 AM
79-93 Mustang 8.8" Rear Differential Width From Hub-To-Hub nightrain_rod Transmission - Rearend 1 12-04-2003 07:59 AM
