b body spindle conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2009, 01:57 PM
if any at all what late model master cylinder should i use when converting a four wheel drum to front disc on a 68 pontiac lemans?
Old 07-07-2009, 03:34 PM
a67tempest455's Avatar
either late model f-body or s10 master cylinders bolt up but the f-body one is on a goofy angle so the s-10 is the best choice.
Old 07-08-2009, 01:59 AM
is there any late model power booster that i can use that will improve brake performance for this conversion?
Old 07-08-2009, 07:46 PM
With B-body brakes, S10 master cylinder, and power boost you will have too little pedal feel and lock up the brakes (if you don't have a spongy pedal). The late model B-body (say 88 caprice wagon) master cylinders are the same externally as the S10 master. If you go with late model master cylinder you might as well go with a S10 booster. They are double diaphragm and some of them are small to help with valve cover clearance. I have 12" B-body brakes on my 87 S10 with the stock booster, 88 caprice wagon master, and it has the perfect pedal feel.
Old 07-08-2009, 10:40 PM
B body spindle conversion
Will the s-10 booster be a direct bolt on? If not what will I have to modify?
Body - Exterior "Tips of the Day" Jon Body - Exterior 11 09-07-2007 12:29 PM
Free Body Diagrams BillyShope Suspension - Brakes - Steering 4 04-27-2007 06:40 AM
HP main body conversion eldee Engine 4 04-13-2007 11:33 AM
Hotrodders Knowledge Base: Body - Exterior Jon Body - Exterior 0 11-26-2005 07:33 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 04:34 PM
