b-body spindles on g-body - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2009, 12:33 PM
runn141's Avatar
will the spindles from a chevy caprice(b-body) fit the balljoints of the g-body cars or an s10? im thinking of doing this swap to get the 12 inch brakes. i hear of this swap but im not sure about the balljoints being the same.
Old 04-19-2009, 04:44 PM
Yes, the ball joints are the same. I'm sure you know that you need to use the Camaro 1LE rotors if you want to keep your 5 x 4.75" bolt circle.
Old 04-19-2009, 04:50 PM
leldai73's Avatar
Its just metal,you're the boss
http://www.darklair.com/monte/12in-brake.html
Old 04-19-2009, 11:33 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Be careful, there are two different B-body lower ball joints depending on HD or non-HD.
There is also a difference in the spindle's geometry, so many times the upper control arms from the G-body are too long. Some guys just use a ton of spacers on the upper control arm to get the proper camber, but it doesn't take full advantage of the B-body's taller spindle.
Lots of tech available on this with a good google search.
Sprayable Body Filler robs ss Body - Exterior 10 11-19-2007 06:56 PM
Body - Exterior "Tips of the Day" Jon Body - Exterior 11 09-07-2007 11:29 AM
T bucket body demensions needed lowROLLERchevy Body - Exterior 3 03-21-2006 06:20 PM
g body spindles mr.chevelle Suspension - Brakes - Steering 0 07-24-2003 11:47 PM
