[B]Looking for TRW pistons - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2007, 06:35 PM
Trying to locate TRW forged piston w/rings Part # L-1359KF .020" (.50mm) oversize - Part # is obsolete & TRW site is no real help on this one so far - Trying to complete a set - Need a quantity of two (2).
Any ideas or suggestions would be welcome.
Jagspeed
Old 05-10-2007, 10:03 PM
trw not around lookup sealed power
Old 05-11-2007, 01:30 AM
DoubleVision's Avatar
Far as I know, speed pro took over the TRW line, and when they did they made some changes. We had a issue years back when one of the TRW forged pistons we were using had broken off a skirt, clean up to the lower ring land for no apparent reason, so we thought no problem, we`ll just get a replacement, we went and looked at the pistons that pulled up under the same part number and the design had been changed, the skirt was shorter and the weight was different, even so the head was the same. We knew this would knock the balance off, so the only way to fix it was, buy a new set of pistons. Believe me, your not the only one who`s run into this same issue.
Blower pistons malibu68 Engine 15 12-14-2006 08:49 PM
? about dome piston's bowtieorbust Engine 5 09-19-2004 07:34 AM
Long skirt SBC pistons fierosum Engine 9 01-16-2004 07:02 AM
Forged Rods and Pistons for Ford 302? Mustang 69 Chile Engine 6 10-21-2002 06:39 PM
