Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - [B]Looking for TRW pistons
Old 05-11-2007, 01:30 AM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
Far as I know, speed pro took over the TRW line, and when they did they made some changes. We had a issue years back when one of the TRW forged pistons we were using had broken off a skirt, clean up to the lower ring land for no apparent reason, so we thought no problem, we`ll just get a replacement, we went and looked at the pistons that pulled up under the same part number and the design had been changed, the skirt was shorter and the weight was different, even so the head was the same. We knew this would knock the balance off, so the only way to fix it was, buy a new set of pistons. Believe me, your not the only one who`s run into this same issue.
