B&M 144 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2007, 06:58 PM
happydad's Avatar
B&M 144
Trying to figure out snout lenght and drive pully size...It has an 8" snout now but no room for the drive pulley...Does any one know the correct combo to fit my 86 vette..Thanks
Old 10-05-2007, 07:47 PM
DoubleVision's Avatar
All I can tell you is, Chevy swapped over to the "long" water pump design in 1969, so the lenth was increased on everything that ran on the system.
The "Short" water pump was abandoned on every vehicle in 1969 also, except the Corvette. I`m not sure what year they stopped using it, but my brothers 85 Corvette has a serpintine system, and the water pump and accessories are the short design. Since no other vehicle used them in those years, you`ll have to find one off a Corvette, your best bet is to look on Ebay or other parts companies.
Late Edit, I just realized you were referring to the supercharger lenth, so I`m not much help to you there, sorry. My best thought would be to call Summit Racing and see what they say, they should know what you`ll need to make it work.
Old 10-06-2007, 04:12 AM
happydad's Avatar
O.K. If I understand this right..If I get rid of the serpintine system and move every thing back towards the block I should have room to clear the steering stuff..If I go with a 1 1/4 drive pulley 2 belt and change the drive pulleys on the alt and p/s pump and go with diff braces that might give me enough room to clear the frame brace and the tie rod...I'll also go with an electric w/p which I have already..Also I would have to go with a shorter snout on the B&M right?? I'm about 2- 3" short now can't fit the B&M drive pulley spacer in the main crank pulley it won't clear the frame brace..Does this sound like a plan..Sure glad I got this blower cheap..What a winter project Anything else you can think of would be helpful..Thanks for your help
Old 10-06-2007, 09:48 AM
im going through the same prob.lems myself.if you measured the snout from the case to the end before the pulley and its 8inches you have the two belt if its 9 inches you have the 3 belt .if you have the short water pump and run the crank pulley without the spacer it should work.wich belt tensioner do you have? snout mount or water pump mount if its water pump you will have to make your own bracket.
Old 10-06-2007, 12:09 PM
happydad's Avatar
Thanks..My snout is 9" and I have the tensioner on it....Now if I remove the serpentine drive pulley and replace it with a 2 belt let's say and change the other pulleys to v-belt,,The blower pulley should mount to the 2 belt w/o the spacer?? It's hard to visualise this with all the serpentine stuff on there...Heck I built the motor with less confusion..LOL
Old 10-06-2007, 04:04 PM
with the 9 inch snout the face of the blower pulley will be 7 inches from the face of the block.the drive pulley face should be 4 inches from the face of the damper with spacer and v belt pulley. if thats to long you can loose the distance of the spacer.but you will need a short snout you can get them through holly.
boost gauge b&m 144 roy383ci Engine 5 06-30-2006 06:57 PM
B&M Blower question Augusto Engine 3 03-19-2006 07:18 PM
Just finish rebuild 144 B&M Blower need little Help ? camaro 77 Engine 7 11-03-2005 07:23 PM
Port ID - B&M 144 Intake Manifold blown81 Engine 0 03-01-2004 02:03 PM
B&M Shift Improver Kit or B&M Transpak nightrain_rod Transmission - Rearend 1 05-19-2003 02:03 AM
