B&M 144 supercharger help - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2012, 06:16 PM
I have a B&M 144 on a 1990 305 Iroc motor. I have had it blueprinted and the heads re-drilled to accept the early intake bolt pattern. I haven't started it yet but all is ready to go. I would like some instructions on how to start and tune and what to set base timing at. Can anyone help? Thanks Dano
Old 05-20-2012, 12:05 AM
BOBCRMAN@aol.com's Avatar
My engine is a 383 with 144 charger on it. Initial timing is at 12 degrees with a total of 36 in at about 2600 rpm. Boost referenced 600. basic carb adjustments.
Old 05-20-2012, 06:12 PM
B&M supercharger
Hey thanks guys I appreciate the help. To update, the engine it is a 30 over stock Iroc roller cam motor with 9-1 compression,charger pulleys are top 3'' bottom 6'', carb is a Holly 600 for superchargers and the dist is a curved hei with a vacuum advance that should do the trick. The cam is a stock iroc roller cam with roller rockers nothing to fancy. Trans is a modified built 700R4 with a 10'' narrowed ford 9'' rear 370 gears. I was thinking I could set the timing at 28 and use an ign kill to turn it over then kick in the dist. Does this help. You guys Rock!!!! Dano
Old 05-21-2012, 12:41 AM
vacuum advance
I am curious why the vacuum would go to the intake instead of the direct port on the carb,is it because of a more constant source ? Do you think I can run 10-12 degrees base with the vac advance pulling to 28-30 ? Dano
Old 05-21-2012, 12:01 PM
B&m 144
Thanks F BIRD for the info and all the tech help. I haven't started the engine since the swap from TPI to supercharger, but plan to this week and will follow your instructions... and will keep you apprised. Thanks again Dano
ps; I see you are a Pont fan, just sold my 71 Lemans convert with the T41 GTO nose. It went to Holland.
B&M 144 Supercharger Manual 75toy Engine 2 03-18-2012 08:52 AM
weiand 144 supercharger Gearhead177 Engine 3 06-11-2009 10:48 AM
142-144 supercharger hottrodz Engine 2 12-23-2006 11:16 AM
BM 144 Supercharger copper522 Engine 0 01-17-2003 01:39 PM
