B+m 144 supercharger question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2009, 03:26 AM
streetrodderbn's Avatar
Certifiable Streetrodder
I have a chance to obtain a B+M 144 supercharger setup for sbc, it comes with extra drive pulley and spare snout,new belts,gaskets,boost advance/retard vacuum for an h.e.i.boost gauges,and all the manuals... a customer brought it in on a 32 3 window I'm working on and the setup is for a long water pump,and the spare drive pulley and snout are for a long water pump also. I had this type of setup in the past, and have a good working knowledge of it. the blower itself looks great, I see no marks whatsoever in the Teflon and no scratches in the rotors and it seems to be in excellent shape. Now to the question.... I can see that the carb opening has been milled out to expose a larger area under the carb-originally, the area under the carb has a rectangle opening that tapers up to the carb base. I don"t know if the modification will hurt the performance/ruined the blower/or made and improvement?!!
Old 04-26-2009, 08:17 AM
I had a 144 supercharger for years and it never gave me a minutes trouble. I sent it to B&M for a checkup after about 25K miles and only the teflon seals were changed.
The only potential problem I can see you might have is for a vacuum leak if too much material has been removed. Get yourself a carb to manifold gasket and have a look.
One more thing, the older 144's had a vent on the snout, the newer one didn't. If you happen to over fill the old units oil vents out and makes a huge mess......ask me how I know. Good luck.
ZAPPER
Old 04-26-2009, 06:52 PM
Calling Jim Davis!!!!
The modification did'nt affect the carb mounting surface, I'm just worried that the modification will hurt the boost/seal of the rotors. If b+m thought the carb opening would have benefited from opening up, why are the holley and weiand 144 blowers still manufactured with the small rectangle opening?!!
Old 04-26-2009, 09:34 PM
are you talking about the square that the rotors ride against? if thats the case it whould reduce the amout of air it pumped.the way they figure size is with the rotors sealed at top and bottom.the space between them and the case is volume.
Old 04-27-2009, 07:09 PM
Yes, the opening on the stock supercharger under the carb is a rectangle @1/3rd the total area of the carb mounting pad in the center. Did this render the supercharger useless? Or at the very least, much less effective, or was it a good modification? I need a supercharger guru on this one!!
Old 04-28-2009, 05:37 AM
B+M Junk Blower!!!
I think I found my answer!!! I found an original b+m technical manual and it states "A 2 lobe rots blower needs at least 180 degrees of rotor to housing contact per rotor to seal properly. removing the area cast beneath the carburetor will destroy this sealing. the supercharger will produce NO BOOST!!" I guess I will have to "pass" on this supercharger that now is nothing more than an engine decoration!!!!!!
Old 04-29-2009, 05:25 PM
Thank god it's not ruined!!!!!!
I got a hands-on with the b+m supercharger. The machining work on the blower was only above the opening, It looks as if the prior owner only machined the opening beneath the carb! I can see the casting of the entire opening, and it has not been altered whatsoever! I'm going to "make the deal" and get this Supercharger for my next project! I would like to find a short drive pulley and snout assembly though!!
Old 12-17-2012, 01:00 PM
hello there bud. do you still have your B&M tech manual?
supercharger.... 73monte Engine 16 07-24-2010 10:27 AM
Supercharger question JustinHebel Engine 0 11-14-2006 10:35 PM
holley 4150 supercharger carbs question malibu68 Engine 7 07-25-2006 10:54 PM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 10:25 AM
