B&M 350 kit thoughts please - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-30-2009, 07:08 AM
I just purchased their 30229 street/strip kit for turbo 350. Anyone installed one or have some first hand thoughts? Thankyou
PS. My engine builder says its plenty good for my street use,375 HP 450 ft/lbs. For what thats worth
Old 10-30-2009, 08:19 AM
SSedan64's Avatar
Should work fine. I'm not sure what modifications their shift kit includes. Look through Jakeshoes TH350 build at the top of the trans/rear section, it has some Mods to the seperator plate etc.. that should be all that is needed.
Old 10-30-2009, 01:21 PM
sqzbox's Avatar
My pipes are my music
Put the drain plug in too! You'll be thanking yourself later!
Old 10-30-2009, 04:59 PM
When I was in my teens I had this beautiful Jade green ford pickup, 351C, bucket seats,four speed. Just to die for. Oil changes back then got done, even when they should, but hey on 4.50 an hour I didnt enjoy the thought of 8 or 9 bucks on oil and a filter, but I grit my teeth and did it. Didnt have a garage ,it was all laneway mechanics. The girlfriend was over. Oh good lord you've never seen the likes of her and with shorts on that had equal parts in as out. As I get my last quart of quaker poured in I'm standing in bare feet wondering what that warm gooey feel is between my toes. Damn them shorts. Yes I will remember the drain plug. Its getting winter up here and even if it werent 40 years have done weird thing to those legs that I seem to be able to keep my mind on drain plugs just fine
Old 10-30-2009, 06:15 PM
sqzbox's Avatar
Actually, I was talking about the trans. pan fluid drain plug that comes with
your 30229 tranny kit. Nice story though, ain't nothing out there that will distract a man faster that the female torso!
Old 10-31-2009, 12:18 AM
bentwings's Avatar
bentwings
I have a B&M o'haul and shift kit in my T350 although I didn't build it myself. I really like it. We deleted the kickdown feature per my instructions and it has worked perfectly so far. I adjusted the mod pressure a little and it now shifts into 3rd at an even 90 mph at full throttle. It shifts hard enough to bark the 14 inch Hoosiers going into 3rd at full throttle. It also can shift nice and smooth at part throttle. Quick and firm but not harsh.
I installed a drain plug and trans temp bung.....after the fact however.
Also installed a Lokar locking dipstick which cured the dipstick leakage.
I have a 3000 rpm converter and trans cooler in front of the radiator. It runs at 150 deg F or less most of the time except when tire testing..haha or on the dyno. Then it goes to 175 max.
Old 10-31-2009, 06:32 AM
A wink from the vertical smile will get ya
B&M shift kit problems.... 1985CHEVYCARLO Transmission - Rearend 1 04-02-2009 12:12 PM
Turbo 350 B&M Deep Oil Pan Filter P/N needed dans29 Transmission - Rearend 1 12-25-2005 02:08 PM
I love my B&M shift Kit! Mightymouse Hotrodders' Lounge 3 06-23-2004 11:18 PM
1984 700R4 B&M Shift kit question Russell52 Transmission - Rearend 4 02-25-2004 10:45 PM
yeah they take a 350 block and get it ready for a 383 stroker kit 79 cutlass Engine 6 01-06-2004 06:53 PM
