B & M aluminum transmission pan - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2014, 12:59 PM
Hwyhogg's Avatar
Last wiki edit: Electrolytic rust removal
Last journal entry: power tour
Have any of you used this pan? good? bad? have a chance to buy one for $100 for my C6. Summit charges 150. Hughes are closer to $200. any thoughts? BTW, it's the 2 extra qt pan.
thanks
Old 02-02-2014, 01:32 PM
JeffB's Avatar
The downside to an aluminum pan is they are easy to crack especially if the car is lowered or if the pan bolts are over tightened,skid plate?
Old 02-02-2014, 04:48 PM
Hwyhogg's Avatar
Thanks Jeff. I've heard these pans actually offer some protection against the trans. case cracking ..from torque?
Old 02-02-2014, 05:23 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the Hughes Performance pan has a thick flange area, very sturdy pan.
Be careful of thin flange aluminum pans, they bend easy at bolt holes
Old 02-02-2014, 06:06 PM
CraigK's Avatar
Last journal entry: For a change of pace
B&M is not known for making junk. Is it the pan with the fins for cooling? I almost bought one just so I had a drain plug on the pan! I am sure there is always a better product. I have only used B&M stuff because thats all I can find locally.
Old 02-03-2014, 07:49 AM
cast pans dont dent...just fyi
Old 02-03-2014, 08:32 AM
Last journal entry: finally got the engine home
great deal!!!! I put 1 one my wifes truck. for easier fluid changes. been there for over 6 years, no cracks, or leaks. I change the filter once every 3 yrs and it hasn't cracked yet. 2 qrts extra, aluminum, fins..........can't beat that for $100.
Old 02-03-2014, 08:44 AM
rick 427's Avatar
Last journal entry: 33 WILLYS
For extra insurance against any pan gasket leaks,run a flat file over the gasket surface of the pan before installing it..You would be surprised,new or used,how many of those aluminum pan surfaces are not as flat as they look.
Old 02-03-2014, 06:58 PM
Hwyhogg's Avatar
Yes, it is the pan with fins..think I'll get it. Thanks guys!
Old 02-06-2014, 04:45 PM
Hwyhogg's Avatar
Got the B&M pan. It already has a threaded port for a temp probe, as twed I will check it for a couple of weeks then compare to the temp using the pressure pot
700R4 Aluminum Pan oldcarguy36 Transmission - Rearend 4 05-18-2008 03:12 PM
power glide pan capacity aluminum pan jsteve068 Transmission - Rearend 2 02-22-2006 06:42 PM
aluminum floor pan bowtiebadboy Interior 0 05-26-2005 09:12 PM
Aluminum oil pan western star Engine 11 11-29-2003 08:03 PM
Aluminum Oil Pan western star Engine 7 10-24-2003 09:44 AM
