B&M blower - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2011, 11:02 AM
B&M blower
hi! what is the difference between a B & M 250 and 420 megablower?
I have a B & M blower I find two number: 18284 on top of the blower and the 5394 cast on the side.
is this a 250 or a 420 blower ?
Old 01-01-2011, 11:13 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
i'm guessing if you post a pic, many guys on here can tell you just by seeing it
Old 01-01-2011, 12:47 PM
blower
try to post a picture
Old 01-01-2011, 12:55 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
I say a 250
Old 01-01-2011, 01:03 PM
XNTRCI-T's Avatar
AKA Lee in KC
I agree with pepi. A 420 is much "fatter."
Old 01-01-2011, 05:15 PM
blower
How This Fits In A Bbc Or Pontiac 400 Engine, Is It Too Small ?
Old 01-01-2011, 08:41 PM
techinspector1's Avatar
Wiki Edits: 326
No such thing as a blower that's too small. You just keep changin' pulleys until you see boost on your manifold gauge.
Old 01-01-2011, 11:44 PM
471A
In terms of "swept volume" the B & M/Weiand 250 is roughly equal to a GMC 4:71 while the B & M/Weiand 420 is roughly a GMC 6:71. If you are intending primarily street use, or a mixture of street/strip use, a 250/4:71 will provide at modest engine rpms more than enough boost than sensibly can be used on the street. If you are instead primarily aiming for drag strip use, then a 420/6:71 would be optimal. To produce the same amount of boost, however, a 250/4:71 must be spun faster than a 420/6:71. That means that the smaller blower will, by comparison, produce more heat, particularly at higher rpms under boost. On the street, at least in my experience, the heat differential in having to spin a 4:71 faster than a 6:71 is not a problem.
Old 01-02-2011, 05:21 AM
blower
as I understand, it is 420 as long as 250 but 420 is higher, does anyone have any size on a 420?
is there any other way I can see the difference?
thanks for all the responses I have received
Old 01-02-2011, 12:29 PM
471A
Following the suggestions of FBird, I found dimensions and diagrams for the particular blowers running through goggle the following: "Weiand Holley 250 dimensions 420 dimensions". Also, including multiple engine dyno runs, I tried to run an 800 cfm atop a 250 blower, first with a carb plate centered in the middle of the blower, then with a "marine" carb plate which positioned the large carb further towards the front of the blower case. Even with the 800 cfm mounted closer to the front of the blower, cylinders 1 and 2 consistently ran much leaner, and much hotter, than cylinders 3-8. Consequently, the engine repeatedly backfired through the carburetor, first requiring replacing a ruptured gasket beneath the "popoff" plate, then having to replace the plate itself because it was bent, and finally, having to rebuild the blower due to bent rotors . Once I went to two 4 fours (2 boost referenced Holley 600s), and locked the timing at 34 degrees (Thanks to FBird), the backfires ceased. In short, although single carb mounts are available for use with the 250 blower, a single carb will not work. I say this after successfully having run a single 800 cfm for several years atop a B&M/Weiand 144 blower. The i44 is, however, much more compact than the much longer 250, and directs the fuel flow more evenly to cylinders.
Old 01-02-2011, 03:12 PM
471A
Here, in summary, are the dyno details demonstrating that a single 800 cfm carb will not work well with a B&M/Weiand/Holley 250 blower. I dug into my files and looked over the many dyno runs made when we were trying to get a single carb to work. With a 1.6 pulley, horsepower peaked at 5800 rpm. At that rpm, cylinders 1, 2, and 3 respectively registered median Exhaust Gas Temperatures (EGT) of 1496, 1488, and 1402 degrees while the median EGT for cylinders 4-8 was 1319. For cylinders 1 and 2, that means they are running about 180 degrees hotter than cylinders 4-8. Given how the 250 blower distributes fuel, when fed by a single carb, the air fuel mixture in cylinders 4-8 is much richer, creating a lower EGT for those cylinders, when compared to the lean condition in the first 3 cylinders, and in 1 and 2 in particular, yielding EGT near 1500 degrees.
Old 01-02-2011, 05:42 PM
blower
thanks for all the information
gmc 6-71 diesel blower to 6-71 blower thats usable on a big block chevy dman16 Engine 10 08-11-2010 10:46 PM
BLOWER MOTOR WITHOUT BLOWER DOKE Hotrodders' Lounge 11 08-13-2009 08:08 PM
Blower or No Blower, That is the question S10 Racer Engine 4 12-16-2007 07:55 PM
Used Blower -- would you buy? 66GMC Engine 10 08-31-2006 03:38 AM
Blower 72dartswinger Engine 3 11-18-2003 09:42 PM
