B&M camshaft specs - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-05-2012, 06:55 PM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
Originally Posted by Chase Knight
The B&M 3444 hydraulic lifter small block Chevrolet camshaft has a .050" duration of 234 degrees intake, 244 degrees exhaust. Cam lobe lift is .3254" intake, .3400" exhaust. Gross valve lift is .488" intake, .510" exhaust, with standard 1.5:1 ratio rocker arms. The lobe separation is 114 degrees. Cam timing at .050" is: intake opens 8 degrees BTDC, intake closes 46 degrees ABDC, exhaust opens 61 degrees BBDC, exhaust closes 3 degrees ATDC.
Regards, Chase
thanks a lot, I really appreciate this.
Augusto.
If you do not want to register, fill this field only and the name will be used as user name for your post.
GM roller camshaft specs Landau454 Engine 2 10-09-2005 07:29 AM
BBC Camshaft Specs sb72elcamino350 Engine 6 06-02-2005 05:00 AM
1969 427 and 1970 454 camshaft specs sb72elcamino350 Engine 1 10-03-2004 07:11 PM
Camshaft Specs PonchoTA79400 Engine 2 02-26-2004 06:00 PM
Camshaft specs. 87442lover Engine 2 02-12-2004 07:55 AM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
