B&M camshaft specs - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-05-2006, 09:39 AM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
B&M camshaft specs
Does anybody knows the specs for the B&M blower 3444 sb chevy camshaft ? I think they called it "super street blower cam"
I lost them long ago and now I need them to install it.
Please help.
Augusto.
Old 12-08-2006, 12:41 PM
Augusto's Avatar
Why is it that I can't find anything about the B&M cams and blowers? when holley bougth them did they sweep the earth of info as well?
I need to degree my cam and have no way to do so.
Please somebody must have one like mine.
Augusto.
Old 12-09-2006, 11:29 AM
Bad Rat's Avatar
Last journal entry: Bad Rats anglia Build Journal plus bike and other photos
Wiki Edits: 2
I'm not sure about the grind you are refering to,, but I had the B&M blower cam, [ I bought it back when B&M was still in business] and it was exactly the same spects as the Edelbrock RPM performer cam.. lift was 488 & 502,, don't remember the lobe sep. or other specs,,, I will see if I can find the spec sheet,, needle in the hay stack kind of thing,,,, Bill
Old 12-09-2006, 02:39 PM
GoneNova/406's Avatar
i have the same problem.i got the same came and lifter set from a friend of mine who wasn't good about keeping info together.all i do know is that its the same cam
Old 12-09-2006, 06:17 PM
cam info
i went out to the garage and looked at the cam i have.its in the original box and says charger cams,b&m,chatsworth,ca. 91311,9152 independence ave.it said the side of the box to use an 850 holley.the cam had 118 M with a circle around it the another mark that looked like'' l l''.thats all i have acept that i stood the cam profiled to my comp cams magnum 280 and it was every bit as big as the magnum with slightly fatter rounder lobes.
Old 12-09-2006, 09:33 PM
Bad Rat's Avatar
Wiki Edits: 2
I couldn't find any parerwork on the B&M cam,, But I am certain that the one I had, was the same spects as the EDL performer rpm,, the edelbrock site shoupd have those spects,, Bill
Old 03-04-2012, 02:04 AM
Superstreet Blower cam specs
I knows its been 5+ years since you asked this question, but I have all the specs and the original packaging for the Super street B&M blower cam, if your still interested? Remember they had two different CAMs, one "street charger" for thier standard blower (144) 6-8 pounds of boost, and a "Super street charger" model for built motors and or motors using the HIGH ENERGY (162) blower running 10-12 pounds of boost. The super model was said to have a rougher idle but still enough vacum to run on the street.
Has anyone run these cams. what was your experience, did they make more power for you ?
Well if you want I can post all the specs tomorrow?
Old 03-04-2012, 09:47 AM
Augusto's Avatar
sure I still want them, I have the super street charger cam, it's installed in a .040 over 350 SBC, I have the 144 blower with the smallest pulley B&M offered for them back in 1998, Iīm restoring this engine thatīs been sitting in a corner for years.
I used this engine as a daily driver long time ago and was a good performer, it idles rather smooth, I expected a rougher idle but didn't get it.
The blower made 10-11 psi of boost, made lots of power and sounded beatiful, I had lots of problems with the belt, the tensioner failed, the mounting bolts at the nose stripped so I fabbed a mount for the tensioner using the alternator base, the one thet goes on top, it worked fine.
I want the specs to dial in the cam perfectly, I think I have it slightly retarded, I want to make sure it runs the way itīs supposed to be.
please post the specs, I would really appreciate it.
Old 03-04-2012, 11:25 AM
Augusto's Avatar
Originally Posted by F-BIRD'88
Specs are 234-244@.050" .488-.510 114 LSA
Summit cam #1107 is exactly the same.
Here is the summit #1107 cam card
http://static.summitracing.com/globa...cam%20card.pdf
You will have to use a solid lifter or read off the edge of the hyd lifter to get accurate degreeing results. If the timing gears are a set, it should degree in within +/-1deg.
The edelbrock performer rpm cam is similar, but on a 112 LSA
I know blowers tame a lot the cam's rough idle, but mine idles like stock, hard to belive it has 244 deg of exhaust, so this cam should be good for something like 400+ horses, I have ported heads and headers in this engine, 7.9:1 CR.
I used to have lots of pingin before, but that was with 882 heads, now it has better heads polished and ported, I expect lower boost reading with this better flowing heads. And hopefully with this low CR I won't have many issues
thanks for helping
Old 03-04-2012, 11:58 AM
Bad Rat's Avatar
Wiki Edits: 2
The infromation I posted is what I used with a B&M 420 blower,, much bigger that the 144, I also have a 144,, or should say I HAD a 144,, untill my son decided he wanted to try it on his Camaro,, its been over 5 years now and he still "trying it out",, so I guess he thinks its his now,,, just like alot of stuff I've bought and ends up on someone elses car
Old 03-04-2012, 07:55 PM
Augusto's Avatar
you'd best check the cam you actually got. You may have the other, milder B&M cam.
214-224 .442-.465 112
I ordered the "super" cam from B&M and on the end it has stamped 3444
I have not found any info to confirm what exactly do I have.
Old 03-05-2012, 02:17 PM
The B&M 3444 hydraulic lifter small block Chevrolet camshaft has a .050" duration of 234 degrees intake, 244 degrees exhaust. Cam lobe lift is .3254" intake, .3400" exhaust. Gross valve lift is .488" intake, .510" exhaust, with standard 1.5:1 ratio rocker arms. The lobe separation is 114 degrees. Cam timing at .050" is: intake opens 8 degrees BTDC, intake closes 46 degrees ABDC, exhaust opens 61 degrees BBDC, exhaust closes 3 degrees ATDC.
Regards, Chase
Old 03-05-2012, 06:55 PM
Augusto's Avatar
Regards, Chase
thanks a lot, I really appreciate this.
Augusto.
GM roller camshaft specs Landau454 Engine 2 10-09-2005 07:29 AM
BBC Camshaft Specs sb72elcamino350 Engine 6 06-02-2005 05:00 AM
1969 427 and 1970 454 camshaft specs sb72elcamino350 Engine 1 10-03-2004 07:11 PM
Camshaft Specs PonchoTA79400 Engine 2 02-26-2004 06:00 PM
Camshaft specs. 87442lover Engine 2 02-12-2004 07:55 AM
