B&M lockup control/700R4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2005, 11:28 PM
Blackdog's Avatar
Anyone using the B&M lockup control with the 700R4? I have the directions for wiring it with a 4 pin plug but mine is a 5 pin. Not sure how to wire it. Thanks
Old 05-03-2005, 08:10 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
talk to B&M?
I do not remeber the pin locations and functions off the top of my head since this was a limited use item ( 5 pin connector).
I'll have to look around to see if I have a connector to determine wire loacations in the 5 pin unit
Old 05-03-2005, 07:23 PM
Blackdog's Avatar
Crosley, if you could check on that it would be great.
B&M only accepts phone calls, no e-mails. I have been strapped with the day job and unable to call.
Thanks for your help.
Old 05-18-2005, 10:13 PM
Blackdog's Avatar
I think the 5 pin uses one pin as a ground. I think the outer pins are the same. Can anyone verify this? Thanks. I'll try calling B&M next week.
Old 05-19-2005, 01:39 AM
malc's Avatar
Living At The Speed Of Life
I´m using one and the connector to the trans was a four pin using only three connections, one is ground.
I installed the kit "as is" works perfect.
I looked at this site http://www.bowtieoverdrives.com/cata...SUBCAT&CATID=O but found no reference to any five pin connector.
I see no references to speed sensors in these kits like the B/M has.
You could do this yourself just buy a relay http://www.700r4.com/tech/tcc/relay_.../diagram.shtml
Old 05-19-2005, 05:35 AM
malc's Avatar
Here´s my stock harness setup.
My four pin connector stock was A = Purple B = Blue D = Tan/Black
I reckon you have to connect the B/M yellow to stock A = Pink and ground D.
How is your connector labeled and do you have the original harness and pics of the connector ?
Old 05-19-2005, 08:00 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I did not forget. We do not have a round 5 pin connector in the shop.
one pin is a ground on the 5 pin, same as the 4 pin square connector
raising torque converter lockup hueysrod Transmission - Rearend 11 06-10-2005 09:26 PM
non lockup vs lockup converters? Sagacious Transmission - Rearend 2 03-25-2005 05:33 PM
Wiring Stall Conveter lockup on 2004r Transmission sb72elcamino350 Transmission - Rearend 2 03-02-2005 08:57 AM
350C lockup plug wiring James Myers Transmission - Rearend 2 08-22-2003 09:50 PM
B&M Shift Improver Kit or B&M Transpak nightrain_rod Transmission - Rearend 1 05-19-2003 02:03 AM
