B&M mega shifter Backup lights - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2011, 07:28 PM
I am trying to wire in my Mega shifter in my 78 Elk. The NSS is working fine. The Backup lights do not. The green wire is the back up and the blue is power. It doesn't work no matter which terminal they are hooked on in the shifter. I pulled these wires from the switch at the base of steering column. Any help is appreciated.
Old 04-21-2011, 05:01 AM
EOD Guy's Avatar
is it the micro switch in the shifter? If you touch the wires together do the backup lights work? The micro switch is very senisitive to adjustments....mine is out of adj with 1/16 of movement.
Old 04-21-2011, 12:06 PM
Not the switch. Nothing happens when the wires are connected.
Old 04-21-2011, 03:47 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
First thing is make sure the BU lights work.
Place a jumper between the blue and green wires.
Replace the bulbs with known working bulbs.
Turn on the ignition and headlights.
If they still don't work check the fuse and check for grounds at the BU lights.
If they still don't work you have a broken wire or a bad connection.
Next thing connect an ohmmeter to the switch to determine if the switch closes in reverse. Adjust if possible.
vicrod
Old 04-21-2011, 07:49 PM
Thanks, I'll check it out.
B&M Mega shifter issues truckboy61 Transmission - Rearend 6 08-31-2010 12:35 AM
ranger backup lights Blob Electrical 5 08-17-2005 08:33 PM
backup lights brenally7 Electrical 9 12-29-2004 04:26 PM
B&M Mega Shifter wiring Chevy Thunder2 Transmission - Rearend 4 05-04-2004 11:34 PM
backup lights lookatme Hotrodders' Lounge 8 02-14-2003 01:12 PM
