Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - B&M Megashifter, only starts in reverse.
Old 07-22-2012, 12:35 AM
White85Camaro White85Camaro is offline
Originally Posted by cullencombs View Post
No adjustment needed. It sounds like you have mis wired your shifter. Looks like you wired you neutral safety switch into your reverse light switch and visa versa.
So basically, if I were to switch the two wires around. It may fix my problem? And if this doesn't do it, I should try doing some adjusting.
