Originally Posted by White85Camaro
So basically, if I were to switch the two wires around. It may fix my problem? And if this doesn't do it, I should try doing some adjusting.
Yes that is why you can start in reverse and your reverse light are on in park and drive. Swap the wiring around on those switches and you will be good.
