B&M Megashifter, only starts in reverse. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2012, 02:39 PM
Last night I put a new B&M megashifter into my 85 Camaro with 700R4 tranny. Everything is in and works. I'm having issues with it not starting in park or neutral. It only starts in reverse. And my back up lights are on when the car is in park and in neutral, but not when I'm in reverse or drive.
If theres anyone with a suggestion or that's gone through this same thing and could shed some light on this issue would be appreciated.
Thanks!
Old 07-21-2012, 04:55 PM
GAOldsman's Avatar
You need to adjust your neutral safety switch.
Old 07-21-2012, 05:38 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I'd agree that is the first place to look
Old 07-21-2012, 09:17 PM
No adjustment needed. It sounds like you have mis wired your shifter. Looks like you wired you neutral safety switch into your reverse light switch and visa versa.
Old 07-22-2012, 01:35 AM
So basically, if I were to switch the two wires around. It may fix my problem? And if this doesn't do it, I should try doing some adjusting.
Old 07-22-2012, 05:49 AM
Yes that is why you can start in reverse and your reverse light are on in park and drive. Swap the wiring around on those switches and you will be good.
Old 07-22-2012, 02:23 PM
Thanks a lot guys! Problem solved!
Old 07-22-2012, 03:16 PM
Good Deal!
Older B&M Megashifter conversion gearhead77 Transmission - Rearend 0 10-12-2007 09:37 AM
B&M Megashifter longt Transmission - Rearend 3 04-25-2005 05:55 PM
B&M Megashifter dollybud Transmission - Rearend 2 07-15-2003 02:27 PM
B&M megashifter on AOD mustang66maniac Transmission - Rearend 0 12-05-2002 12:06 AM
Stock column shifter into B&M megashifter MuscleBlock81 Transmission - Rearend 2 09-12-2002 12:32 AM
