72 nova
Iam putting a bm pro stik in with a powerglide im a little confused about the valve patern any suggestions the shifter cable is front entry is that correct? any pointers? thanks frank
welcome to the board..... I split your post from the thread you used since it was 3 yrs old. This will provide more answers to your question. You need a shifter to match your shift pattern on the trans.... A regular pattern or reverse shift pattern? Reverse is P R N L D Forward pattern is P R N D L on a glide Good luck |
| All times are GMT -6. The time now is 02:32 PM. |
