B&M Pro Stick with a powerglide - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2007, 07:42 PM
72 nova
Iam putting a bm pro stik in with a powerglide im a little confused about the valve patern any suggestions the shifter cable is front entry is that correct? any pointers? thanks frank
Old 06-04-2007, 07:45 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
welcome to the board..... I split your post from the thread you used since it was 3 yrs old.
This will provide more answers to your question.
You need a shifter to match your shift pattern on the trans.... A regular pattern or reverse shift pattern?
Reverse is P R N L D
Forward pattern is P R N D L on a glide
Good luck
