B&M Quicksilver shifter with a new Turbo 400 w/reverse manual valve - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2012, 07:55 AM
dasyhard's Avatar
I just purchased a new turbo 400 with a reverse manual valve body and I currently have a B&M Quicksilver shifter mounted in my '34 ford. The old trans was a Turbo 400 auto so the shifting was a forward pattern and I usually used the "Drive" position. This new trans will require an opposite shifting pattern P,R,N,1,2,3. Can I use this same shifter? Would I need a reverse plate mounted or any fabrications done? I don't have a transbrake. I appreciate any recommendations.
Old 07-05-2012, 02:29 PM
SSedan64's Avatar
The Shifter will work with RMVB but, the Indicator Window will be off.
You will need BMM-80618 window for PRN123 pattern. May only be available from B&M.
Contact Us | B&M Racing and Performance Products
The Following User Says Thank You to SSedan64 For This Useful Post:
dasyhard (07-06-2012)
Old 07-05-2012, 05:23 PM
dasyhard's Avatar
I appreciate your feedback. I will make that part# purchase. Thanks
Old 07-06-2012, 07:38 AM
dasyhard's Avatar
I can't get ahold of them. The B&M phone lines are constantly busy with only a recording saying to call back another time. And the online parts catalog do not have part number 80618 listed. Any suggestions?
Old 07-06-2012, 07:50 AM
dasyhard's Avatar
Disregard, I finally got ahold of them. The rep indicated they were moving so they were short on phone lines.
T-400 reverse manual valve body problems huafist Transmission - Rearend 11 02-25-2010 06:40 AM
Reverse lockout on quicksilver? Kurt64 Transmission - Rearend 5 01-31-2010 02:58 PM
Turbo 400 manual valve body Tbucit Transmission - Rearend 2 07-26-2006 08:38 PM
Turbo 400 Manual valve body Tbucit Transmission - Rearend 3 05-10-2006 09:30 PM
Turbo 400 with manual valve body & reverse pattern... Bumpstick Transmission - Rearend 5 12-26-2005 03:51 PM
