B&M Shift Kit - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2005, 11:12 PM
B&M Shift Kit
I took the valve body off of a TH350 trans that has a full manual kit of some sort installed, perhaps B&M. There is a bunch of washers on the servo piston, and the over run band cannot apply. Is this the reason for the washers? Can I remove the washers and get engine braking in 2nd again? Has anyone installe one of these kits and still have the instruction sheet? I cannot see any other purpose for these washers. Any help would be greatly appreciated. Thanks in advance.
Old 08-10-2005, 05:19 AM
Last journal entry: PICTURE TEST
kit
If the seperator plate has the transfer plate attached to it then it is probably a trans -go kit. As far as i know the trans-go kits are the only ones that use the washers under that servo....
i think i have a set of instructions for it if you can get the part number off of the transfer plate to confirm..
keith
b&m Shift improver kit need help th350 onebad98z Transmission - Rearend 3 04-20-2005 07:16 PM
I love my B&M shift Kit! Mightymouse Hotrodders' Lounge 3 06-23-2004 10:18 PM
1984 700R4 B&M Shift kit question Russell52 Transmission - Rearend 4 02-25-2004 09:45 PM
probellems with b&m shift kit LoudMalibu Transmission - Rearend 9 03-26-2003 09:16 PM
TH350 B&M Shift Kit bizkit075 Transmission - Rearend 0 02-01-2003 10:34 PM
