Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - B&M Shift kit - Governor clicking
Old 06-10-2006, 06:30 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by gilby246
Yes, I am complaining
it does work correctly... just sounds absolutly god awfull horrible under load and bad the rest of the time
if the tranny works correctly........
A governor is not going to sound
you have other problems.
check for flywheel cracks , loose bolts , .
do you have a dust cover on the tranny at the flywheel? Is it a possible problem ?
