-   -   B&M Shift kit - Governor clicking (http://www.hotrodders.com/forum/b-m-shift-kit-governor-clicking-91423.html)
gilby246 06-10-2006 12:48 PM
I just got done doing a complete rebuild to my TH350 and installed a B&M shift improver kit street/strip. The transmission had no issues prior to the rebuild besides needing new clutches . After putting it all back together and taking the car for a ride I could hear the governor clicking. I jacked it up and turned the driveshaft by hand and could hear it. To verify I popped open the cover and could see it as it clicked (the weights falling) took it out to verify and it stopped. I replaced it with another, put it back together and its doing the same thing. I have since taken the valve body out to make sure the governor screen or line wasnít clogged but it was fine ( I replaced it anyway). Although there was fluid behind the cover I suspect that the governor is not getting full line feed but I donít know why.
I had a friend who builds transmissions for a living help me on this one and trust everything was done properly.
I donít know if this is shift kit related or another reasonÖany ideas or suggestions would be appreciated
BTW- In my frustration Im sure I left out some important info so please ask if more is needed
Crosley 06-10-2006 03:36 PM
you complain about clicking noise.
does the tranny NOT function correctly ?
No shifts?
soft shifts?
gilby246 06-10-2006 03:55 PM
Yes, I am complaining
it does work correctly... just sounds absolutly god awfull horrible under load and bad the rest of the time
Crosley 06-10-2006 05:30 PM
if the tranny works correctly........
A governor is not going to sound
you have other problems.
check for flywheel cracks , loose bolts , .
do you have a dust cover on the tranny at the flywheel? Is it a possible problem ?
