B&M Shift kit - Governor clicking - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2006, 01:48 PM
I just got done doing a complete rebuild to my TH350 and installed a B&M shift improver kit street/strip. The transmission had no issues prior to the rebuild besides needing new clutches . After putting it all back together and taking the car for a ride I could hear the governor clicking. I jacked it up and turned the driveshaft by hand and could hear it. To verify I popped open the cover and could see it as it clicked (the weights falling) took it out to verify and it stopped. I replaced it with another, put it back together and its doing the same thing. I have since taken the valve body out to make sure the governor screen or line wasnít clogged but it was fine ( I replaced it anyway). Although there was fluid behind the cover I suspect that the governor is not getting full line feed but I donít know why.
I had a friend who builds transmissions for a living help me on this one and trust everything was done properly.
I donít know if this is shift kit related or another reasonÖany ideas or suggestions would be appreciated
BTW- In my frustration Im sure I left out some important info so please ask if more is needed
Old 06-10-2006, 04:36 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
you complain about clicking noise.
does the tranny NOT function correctly ?
No shifts?
soft shifts?
Old 06-10-2006, 04:55 PM
Yes, I am complaining
it does work correctly... just sounds absolutly god awfull horrible under load and bad the rest of the time
Old 06-10-2006, 06:30 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
if the tranny works correctly........
A governor is not going to sound
you have other problems.
check for flywheel cracks , loose bolts , .
do you have a dust cover on the tranny at the flywheel? Is it a possible problem ?
b&m Shift improver kit need help th350 onebad98z Transmission - Rearend 3 04-20-2005 08:16 PM
I love my B&M shift Kit! Mightymouse Hotrodders' Lounge 3 06-23-2004 11:18 PM
1984 700R4 B&M Shift kit question Russell52 Transmission - Rearend 4 02-25-2004 10:45 PM
B&M Shift Improver Kit or B&M Transpak nightrain_rod Transmission - Rearend 1 05-19-2003 03:03 AM
probellems with b&m shift kit LoudMalibu Transmission - Rearend 9 03-26-2003 10:16 PM
