Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - B&M shift kit insallation
Old 04-09-2002, 01:21 PM
Dave E Shank's Avatar
Dave E Shank Dave E Shank is offline
Post
I put one of those >$30.00 shift kits in a 350 Turbo. The little ball shifted to a spot to where is was not supposed to be. The result was a lot of hunting for correct gear at between 20 to 30 MPH. Also as soon as I took off transmission would shift from first to second before building up torque. I called all the 800 tech lines but no real answers. I bought a Transco kit from Summitt Racing which is easy to install with great instructions including a video. That is when I found the misplaced ball. The Transco kit is woth the $ 60.00 or so bucks. It kind of boils down that you get what you pay for.. GOOD LUCK davesr@trianglesalesusa.com
