B&M StarShifter ratcheting problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2013, 06:58 PM
Hey all! Thought I'd see if anyone has some experience with B&M's StarShifter? It's in a 66 Mustang with a C4. It ratchets between low 1 and low 2 as it should. But absolutely wont from low 2 to drive. I've put about 300 lbs of white lithium all over it (or it seems like I have) and worked it like crazy but it didn't fix it. No problems shifting at all between any of the gears and neutral when its not in the ratcheting mode. Not sure why it works from low1 to 2 but cant ratchet from low 2 to drive. Any ideas or suggestions? I don't see any visible damage anywhere.
b&m, ratchet, starshifter
Ratcheting sound when I turn??? Bauer1287 Suspension - Brakes - Steering 9 01-28-2011 04:10 PM
stubby wrench ratcheting or not tomthecomic Garage - Tools 2 09-27-2008 12:23 PM
B&M Starshifter Mods Machinist59 Transmission - Rearend 1 05-27-2007 06:04 PM
B&M Starshifter, do they make boots? Rubberman2003 Interior 1 09-25-2003 08:02 PM
DOES ANYONE HAVE AN OLD SET INSTRUCTIONS TO INSTALL B&M STARSHIFTER 67RS-Groundpounder- Transmission - Rearend 1 03-24-2003 04:21 PM
