B&M Street Rod Shifter? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-19-2006, 08:41 PM
Anybody here have one? I need to purchase a shifter for my project and am considering the B&M as an alternative to the Lokar and Gennie. Opinons and comments appreciated.
Bob
Old 12-20-2006, 08:03 AM
Bob,
The best suggestion is to try each of them to see what you like and/or dislike about them. I did that earlier this year and decided on the Lokar shifter. I didn't care for the gated setup in Gennie and B&M.
Good luck,
Ed
Old 12-21-2006, 10:39 PM
I have a B&M shifter that I took out when I converted to coulmn shift. It was working fine when I took it out and would like to sell it. I have no idea what it is worth if you are interested make me an offer. slpbp@bellsouth.net
Old 12-21-2006, 11:09 PM
Frisco's Avatar
Glad To Be Here
Bob
I have used the Lokar. Installation was easy and the unit worked very well. The only thing I didn't care for was being limited in my choice of shift knobs. Seems they all need the pushbutton. I recently saw that Speedway offers an adapter for the Lokar shifter to enable the use of any shift knob you desire. I didn't see that before I order my Gennie shifter.
I opted for the Gennie this go round. Installation of this unit was also easy and I like the gated feature. This setup allows a greater choice of shift knobs as no pushbutton is required. The thread size is somewhat small in diameter though but should be OK.
Both units have the neutral lockout switch included.
The only thing about either shifter that I do not like is that either can be up-shifted past DRIVE and directly into NEUTRAL with ease. Not good in my opinion.
I haven't tried the new B&M Shifter yet. It looks very much like the Lokar unit except the shift lever bolts on. I have used some B&M products in the past and like them.
Old 12-22-2006, 06:38 AM
I haven't tried the new B&M Shifter yet. It looks very much like the Lokar unit except the shift lever bolts on. I have used some B&M products in the past and like them.[/QUOTE]
The B&M appears to be detented like the Lokar rather than gated like the Gennie Shifter. I haven't seen one, but it appears that to move the stick out of "park" or "neutra"l, you push down on the stick rather than a knob button as in the Lokar.This should mean that you can use any knob. That's the big draw for me. I'm aware of the Lokar adapter that allows the use of other knobs, but it appears to be rather large and bulky. Looks sort of weird when installed on the stick because it disrupts the stick's nice taper.
Bob
Old 12-22-2006, 07:21 AM
Last journal entry: Headlights added
Have one for sale.
Steve
ID:	17042   Click image for larger version
Street Rod and Rat Rod Woody31coupe Body - Exterior 23 08-09-2008 02:19 PM
How to build street rod alawson Introduce Yourself 6 01-21-2006 08:40 PM
5.7" vs. 6" savman1 Engine 30 01-20-2006 09:17 PM
1st street rod project chev32 Introduce Yourself 3 01-05-2006 08:21 PM
b&m shifter kit question idid35 Transmission - Rearend 2 11-18-2003 06:45 PM
