B&M TORK CONVERTER ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2005, 09:27 PM
I'm wondering what is the difference between the b&m hole shot converters and the tork master converters? I do know the hole shot converters are used to achieve better launches, but what does the tork master converter improve?
Old 06-04-2005, 10:18 AM
DoubleVision's Avatar
The tork master isn`t made for high power applications, you`ll see on them "not for big blocks" since it`s likely a big blocks torque would gut it. A hole shot converter is made better and is meant to withstand more power and abuse. A tork master is fine for the basic street machine with a small block, but I remember seeing in the past "perfect for street bound small blocks making under 400 horsepower"
TCI Stall Converter - Blown SB 68NovaSS Transmission - Rearend 10 09-09-2008 12:42 PM
TPS sensor and Converter question. Parisienne66 Engine 5 05-12-2005 10:50 PM
TH350 gap between converter and flexplate QUESTION chrisgarrison Transmission - Rearend 6 12-26-2004 11:32 PM
B&M stall converter Lthompson Transmission - Rearend 6 11-29-2004 03:04 PM
possible bad toque converter? Deadtemple Transmission - Rearend 9 10-11-2003 06:53 PM
