-   -   B&M Torkmaster 2400 rpm stall converter vs. stock torque converter??? (http://www.hotrodders.com/forum/b-m-torkmaster-2400-rpm-stall-converter-vs-stock-torque-147454.html)
zbhover 10-30-2008 09:01 PM
Hello, I have a chance to buy a B&M Torkmaster part number 20404 2400 rpm stall converter for a th-350 for $65.00 that has about 3000miles on it.
Is it worth it??? What if any improvements would I see compaired to the stock th350 torque converter, with a basically stock 77' 350. This is all going to go into the 350 beetle that I'm building.
Thanks for the help
bye
C-10 11-02-2008 05:29 PM
You may have already bought the converter.
So the question, was it worth it to 'you' ?
You should notice around a thousand rpm stall increase over the stock converter off the brake pedal.
You may find that a car as light as yours may like a stock converter unless the engine doesn't idle good.
zbhover 11-02-2008 08:52 PM
I didn't buy it, I figured that if it wasn't going to make a big differance then I could find a better way to put the $65 in the project.
The engine idels good, its a stock 77' remanufactured 350 with ~5000miles on it with an eldelbrock performer intake.
