B&M Torkmaster 2400 rpm stall converter vs. stock torque converter??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-30-2008, 09:01 PM
zbhover's Avatar
V8 Beetle & Hovercrafts
Hello, I have a chance to buy a B&M Torkmaster part number 20404 2400 rpm stall converter for a th-350 for $65.00 that has about 3000miles on it.
Is it worth it??? What if any improvements would I see compaired to the stock th350 torque converter, with a basically stock 77' 350. This is all going to go into the 350 beetle that I'm building.
Thanks for the help
bye
Old 11-02-2008, 05:29 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
You may have already bought the converter.
So the question, was it worth it to 'you' ?
You should notice around a thousand rpm stall increase over the stock converter off the brake pedal.
You may find that a car as light as yours may like a stock converter unless the engine doesn't idle good.
Old 11-02-2008, 08:52 PM
zbhover's Avatar
I didn't buy it, I figured that if it wasn't going to make a big differance then I could find a better way to put the $65 in the project.
The engine idels good, its a stock 77' remanufactured 350 with ~5000miles on it with an eldelbrock performer intake.
Build for Hp or Torque? Venturat Engine 76 09-23-2008 11:22 AM
Torque Converter Question newbielike Transmission - Rearend 2 12-17-2007 06:53 PM
torque converter spankthru Transmission - Rearend 2 09-29-2003 02:38 PM
camshaft help novatech Engine 7 05-29-2003 10:42 AM
stall torque converter beetle9 Transmission - Rearend 11 12-28-2002 05:34 PM
