Are B&M torque converters rebuildable? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2012, 08:56 PM
swp1983's Avatar
I have a B&M Tork master 3000 stall converter. Just wondering if they can be rebuilt and how much that should cost? My budget does not allow for a *****en $700 converter, may consider a Jegs converter also.
Thanks gents!
Old 05-05-2012, 12:35 AM
JeffB's Avatar
The big box auto parts stores buy converters from outside sources,to eliminate the middle man check these folks out: http://www.roadrunnerconverters.com/
Old 05-05-2012, 10:17 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Thanks gents!
the converter can be rebuilt. Depends on what you want changed or what the parts converter needs to fit your application as to what costs will be
Old 05-07-2012, 07:11 AM
Last journal entry: Still running strong
I had a 200r4 torque converter worked on.Changed it so I could plug it into a 700r4.New stator,cost me 80.00.
Big End & TSI torque converters??? yragat Transmission - Rearend 3 09-27-2008 02:28 PM
torque converters DougGass87 Transmission - Rearend 1 09-21-2006 11:19 AM
Th350 & Th400 Torque converters Houman SS '70 Transmission - Rearend 5 06-14-2005 05:18 AM
Torque Converters schuffm Transmission - Rearend 2 10-30-2004 01:21 PM
Torque Converters: Do They Multiply Torque? purple1967camaro Transmission - Rearend 1 04-28-2004 10:41 PM
