B&M TRANS PACK HELP - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2002, 10:18 PM
Post B&M TRANS PACK HELP
OK I GOT A SHIFT KIT FOR MY TH350 TURBO IT HAS 3 DIIFFERNT SETINGS RV,STREET, AND COMPITOIN I WAMTED TO PUT COMP ON BUT, I DRIVE IT ON THE STREET WOULD THE CAR RUN OK ? I GOT STREET ON AND I FEEL A LITTLE OF A DIFFRENCE. BUT SOMETIMES IT DOESNT WANT TO STAY IN GEAR AND SOMETIMES IT WILL SHIFT HARD, I WANT IT TO SHIFT HARD ALL THE TIME. DID I PUT IT IN WRONG CAN SOME 1 HELP ME.
Old 09-10-2002, 05:36 AM
Barry.M's Avatar
Old Phart
Last wiki edit: How to identify a Ford V8
Last journal entry: 27 T Roadster project-For Sale
Wiki Edits: 3
Red face
Hi Insane. How many miles are on your trans ?. Have they been "hard" miles ?. If your trans is high mileage or getting tired, a shift kit won't inprove it much. Did you put in a new batch of trans fluid when you installed the kit?. When you pulled the trans pan,was there any debris in the bottom?. If so,it could need a rebuild. With an O.K "high mileage "trans,try some "Ford" grade trans fluid for C4-C6,it's a bit thicker and will increase line pressure a bit,GO CAREFUL !!!.
The Street shift kit should give you a firm to hard 1-2 change and a firm 2-3 change.This IS NOT taking into account Engine HP and Stall Speed which will affect shifts. The competition version is "Hard" on ALL shifts and not pleasant for everyday driving.
As far as not wanting to stay in gear,I think this would be an adjustment problem with the cable kick down.
Hope this helps........Cheers.....Barry.M
