B&M transkit - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2006, 02:55 PM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
B&M transkit
I've been thinking of buying a B&M transkit for my TH350 from Summit, how good is this kit? doest it come with everything for a "normal" trans rebuild? clutch disks and steels, band, seals, gaskets, etc. plus the parts from the shift improver kit? my trans works now but would like to improve it a bit + adding the shift improver.
please let me know your experience.
Augusto
Old 04-15-2006, 08:12 PM
Go to B&M's website to clarify their kits and components.
B&M valve body kits DO work....
Old 04-15-2006, 09:01 PM
steve t's Avatar
ex biker, now hotrodder
there shift kid works great for harder shifts, but they do not rebuilt your trans if it need help, easy to install, hello from across the water
Old 04-25-2006, 09:14 PM
Warrant's Avatar
72 Nova, 65 Rambler, 37 Chevy
Im am also thinking of buying this kit, But I have heard many bad things about B&M. I beleive it comes with shift kit for to convert valve body to manual/atuo? kits "DO" work? you mean that in a bad way? Also is it just a stock rebuild, or are the cluthes and stuff higher quality? "but they do not rebuilt your trans if it need help" will this kit work for a 100000 mile good condition little sludge trans behind a 400HP engine with 2800 stall and external cooler? is the hardend race, bushings in the sun gear, the ford bushings in direct drums etc needed for 400 hp and 2800 stall? Thanks!
B&M Megashifter longt Transmission - Rearend 3 04-25-2005 04:55 PM
B&M stall converter Lthompson Transmission - Rearend 6 11-29-2004 03:04 PM
B&M Pro Gate Shifter 73monte Transmission - Rearend 1 09-15-2004 08:46 PM
B&M Shift Improver Kit or B&M Transpak nightrain_rod Transmission - Rearend 1 05-19-2003 02:03 AM
B&M vs. TCI vs. Other Transmission Kits jvenice Transmission - Rearend 3 11-02-2002 11:48 AM
