B&M Transpak vs Shift Kit - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2007, 08:39 AM
I have a 72 truck with V-8 350ci., mild cam, headders, 4-BBL with rebuilt 350 Th-350 auto transmission. What is the difference in the B&M Trankspak vs. Shift Improver Kit? I am looking at the Stage II- Hi-Pro/Street/Strip option. The Transpak states you can downshift at any speed and hold the transmission in first gear to any speed you want. My question for a quick shifting mostly street driven truck, which kit would be the better choice? There is only about $30. difference, so which kit would you buy? Also what about "Improves Transmission Life"?
Old 02-24-2007, 08:23 AM
Frisco's Avatar
Glad To Be Here
I have installed the B&M Transpak in two different TH-350 transmissions. One with the trans in the vehicle and one that I put on a stand. The installation is very easy (I had never even dropped the pan on an automatic before). I really was pleased with the results. I used the Stage 2 Street option. Shifts were very firm. Up Shifts at WOT were awesome.
As to "improving transmission life"; I don't know. Seems to me that the reason for installing the kit using the option I did would not increase the life as it is a performance improvement which would have a tendency to increase the overall "wear and tare" on the trans.
Modifying th350 valve body at home - Custom shift kit? Warrant Transmission - Rearend 5 11-24-2006 07:39 AM
shift kit rebuild kit help roy383ci Transmission - Rearend 1 03-26-2005 07:17 AM
trans shift kit chev kev Transmission - Rearend 4 02-08-2005 07:32 PM
SHift kit smokin1980chevy Transmission - Rearend 5 09-03-2003 11:03 PM
B&M shift kit insallation jmi Transmission - Rearend 5 04-09-2002 11:13 PM
