B.O.P trans to Chevy eng - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2012, 09:22 PM
Has anyone ever used one of those adapters that allows the use of a BOP TH-400 to a Chevy engine? Any issues? Does the torque convertor bolt up ok with the extra clearance of the adapter?
Thanks
Old 08-24-2012, 09:44 PM
BOBCRMAN@aol.com's Avatar
Not only have I used them. I have made them. The block/trans locator pins are in the same location on all these trans. Chev+67 later BOP and Cadillac. A simple piece of 1/8" plate, a means to cut it (torch, band saw, p-cutter), a 3/8 drill and a couple of weld nuts and you have an adapter.
The torque convertor is spaced the equal amount with 1/8" washers between the flexplate and convertor.
Old 08-24-2012, 09:57 PM
Cool. I'm looking at getting this one.
Trans-Dapt Performance Products 0060 - Trans-Dapt Performance Transmission Bellhousing Adapters - Overview - SummitRacing.com
Anything else I need to be aware of? The trans is off an Olds 455, & it will be bolted behind a 327 SBC
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks
They work fine. I've used them to bolt a BOP engine to a Chevy tranny and vice versa. I've even used one to bolt a Pontiac 455 to a 4WD tranny/transfer case in a Chevy Blazer. No probs.
4.3 Marine Eng To A 350 Chev Eng DAN CASPER Engine 2 07-19-2010 08:56 PM
78 Nova/86 Monte eng,trans swap 78 Nova Project Transmission - Rearend 5 04-22-2010 04:26 PM
1962 Lincoln Continental factory 430ci/fordmatic? What eng/trans will swap out? milehightoyz Engine 17 06-11-2006 06:35 AM
28 chevy eng mods 28 chevy Engine 1 05-18-2006 01:37 PM
aod trans 352 eng bowtie56jw Introduce Yourself 1 12-27-2004 02:26 PM
