Back to 400sbc balancing! - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2004, 01:37 PM
My sbc 400 external balanced has a vibration despite using the correct flexplate with the big counterweight & a brand new Summit external balance dampner. It also had a new Summit higher stall converter (1 up from stock) . I hurried getting it in so didn't do the usual tear down & pro balance. Can the flexplate be on backwards or out of rotation? Right now the weight faces the engine side not the trans side. Could the Summit converter be O.O. balance?? Coulsd someone have put a 350 internal balance crank in the 400 B4? Its in a '37 ford & no room to pull the trans back so I have to take half the front of the car off to get it out again so any thoughts B4 this would be appreciated!!
Old 06-11-2004, 03:24 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
I've heard bad things about the summit dampners.
Old 06-11-2004, 04:56 PM
Oh also, I checked the relationship between the front balancer counterweights and the one on the flexplate. If the harmonic weights are at 2:00 the one on the flex is at 8:00 so they are 180 degrees part which should be ok?? Also, the vibration is exactly the same before and after the new balancer so likely not it!
Old 06-12-2004, 07:44 AM
37, I feel your pain since I have been playing with a 36 coupe for 44 years and a 36 pu for 30 years. I finally broke down and rebuilt the x member to allow me to pull tranny without pulling the motor and can now pull motor with only removing 1/3 of the front end. My thoughts are that you may have a 385, not a 400. The 385 is a 400 block with 350 crank, which is internally balanced. Since you had an out of balance condition when you changed the harmonic balancer and flexplate, I assume you bought the car/motor with this problem. Additionally, previous builder could have converted to a internally balanced setup. And last thought, I have only ran into one torque converter that was out of balance so even that is a very remote possibility. If it were me, I would do some serious sleuth work trying to find the history on the motor before turning one wrench!!
Trees
Old 06-12-2004, 12:20 PM
MI2600's Avatar
Member# 3287
When you said you didn't do the "normal pro balance" did you mean you didn't have the internals balanced? If so, if you changed any of the internals you probably nixed the balancing.
Old 06-12-2004, 12:59 PM
No, I didn't have it balanced & didn't even pull the pan as I heard it running B4 I bought it & it was smoke free & solid. It was in a Blazer which had been crashed though so couldn't drive it & didn't notice the vibration. All I did was drop the front of the pan a bit so I could install a Summit cam, chain & gears. & a built th350 trans & Summit converter out back. No history available so I guess I'll have to pull it anyhow though sure would like to wait until the summers over. Also, can a converter be balanced properly after it has been running in a car?? I ask as I know its near impossible to comletely drain out the fluid so a static balance would seem impossible!.
Old 06-12-2004, 03:42 PM
MI2600's Avatar
Member# 3287
Sounds like you've got the flexplate on correctly (weight toward the block) and if I read correctly the vibration occurs with two different balancers.
Could the crank have been bent in the Blazer's accident?
I had a vibration in my 406 when I was using one of those balancer plates with a 350 flywheel. After I put a 400 flywheel on it, it stopped.
